Hi, I'm looking to do the same thing, but local Nissan dealerships want close to $500 for the Maxima MAF and they say it won't fit a QX4. Did you buy your MAF new from a Nissan dealership?Chris92SE wrote:*Update*
I did some searching and found out that a 2001 Maxima MAF will work on my 2001 QX4.
I bought the Maxima MAF for about $120 from my local dealership. They wanted almost $500 for the QX4 one. You can even get the Maxima MAF sensor cheaper if you shop around, but I was short on time and there is only one dealership within 90 miles of me.
Anyway, I swapped in the Maxima MAF, left the battery disconnected overnight and the next day everything was fine. No more pinging/knocking and it seems to have regained a lot of power. The SES light never came on and hasn't. I have put about 600 miles on it since the swap and everything seems to be fine.
I would like to add that I am not a professional mechanic and I cannot guarantee this will fix your problem, but it worked for me and my 2001 QX4.
The Nissan part number is: 22680-2Y001 if anyone is interested in attempting the same fix.
Modified by Chris92SE at 7:40 AM 10/14/2007
My coworker and I both just did the fix -- his 2001 Pathfinder and my GF's 2001 QX4. We both had the P0171 bank too lean code. We got the part (22680-2Y001) from http://www.infinitipartsusa.com for about $78 plus shipping. He now has no codes, but a P0160 showed up for me -- rear O2 sensor. Both of us have a MUCH better running vehicle, power like they were new. We just installed, reset the codes. At first I had a too-rich code, until the ECM figured it out and adjusted the trim away from the settings to which it had adapted with the bad MAF.AJRK wrote:
Yeah, you have to ask for the specific part number. It should be under $150.AJRK wrote:
hmm...I am not even sure what that code means?Pathy24 wrote:hey guysI just did the mfc sawp (maxima to pathfinder) runs awesome now, but i have a new code now p0420DTC P0420 (RIGHT BANK, -B1) THREE WAYCATALYST FUNCTION
any thoughts??
hey, have the same problem with the maf (knocking) - just replaced the gaskets fro throttle and intake plenum after cleaning and slapped on some iridium ngk - i feel there is more power but the pinging is still there - i luckily purchased one from craiglist (used for 3 weeks then xdent) fro 150 and i figures even better than going to maxima xchange - so when i turned on car it ran real rich for about a minute or two and lots of smoke - in reaction i just replaced with old maf after cleaning and idle came back to normal - so its been this way since - so the question is how long was your truck 'learning' before it stabilized and you drove off - i will attempt to re install after leaving the battery disconnected fro a few hours and want to know what to expect (the mechanic suggested that it was a rip off and that the MAF seller tampered with the inner parts and resealed it) -attofarad wrote:
BTW, I measured the direct MAF voltage vs. RPM on the old/bad MAFs. For both of us, the voltage was low but well within the shop manual specified range. So, bad even though tested sorta okay.
I went right to the dealership and bought the maxima maf for <$150.vq35 wrote:checked for maf sensor on 2001 maxima at the infinitiparts site you suggested and the $ was around $400 for both the 3.0/3.5 of the same year - were they having a sale or something when u purchased?? anyone point me in the right direction for the 'under' $100 maxima maf sensor - i have no confidense that my used maf will work out (i will still try n post results) thanks for any help!
hey all,found a dealership (nissanparts.cc) for the maxima MAF - just finished install and took the pathy for a spin and it was just fantastic - its late so everwhere was empty (redlined in 3rd and 4rth....fifth got a bit scary so i backed off!!) NO MORE FKIN PINGING IN ANY GEAR !!!!!!! for LESS than a hundred bux and about 20 minutes to put together (preceded by disconnected batt. of course) meself !!!!!this started a month or so ago and i have since documented the following - NGK iridium plugs new gaskets for intake plenum as well as throttle body 2 cans of throttle body cleaner for both the intake and throttle body (lotsa gunk removed and back to new) PCV replaced new belts/coolant flush THE LAST ITEM REMAINED THE MOST EXPENSIVE AND ELUSIVE FOR A TIME -the FKN MAF, replaced it just now and no programming, no hassle bolt on solution to a renewed vq3.5 VERY happy and the next mission is the suspension and rear end i will post pix of process as soon as i figure out how to do this stay posted for the rest later onthanxvq35 wrote:im in toronto and my local dealerwship quoted around $400 for both the maxima and pathy maf - is there a parts store online or otherwise that i can ship to toronto for around the $150 mark (which dealership did u deal with, maybe i can have them ship to me for the same amount you paid) - this has been a pain in the *** for the longest time but i have a feeling that once covered, i will be ok for a long while
again thanks for any help
i ordered the same part from the same place, everything works awsome, just wondering if you are going to get your ecm reprogramed, as it was suggested with the note enclosed in the package, do you think its necessary? ANYONE???????vq35 wrote:
