brianw »
https://forums.nicoclub.com/brianw-u65970.html
Sun Aug 05, 2007 9:54 pm
VQ35DE's share the same bellhousing bolt pattern for the transmission with the VQ30DE, I don't know about your Frontier.
Your VG33 ECU should be able to run a VQ35, but you won't have VTC's (not that big a deal) and a host of other more minor issues. The biggest one is feeding the ECU the proper cam timing signal as the VQ35DE system on the Maxima/Altima/350Z/G35 is completely different than the VG, which is also different than the VQ30DE. I haven't ever looked at the VG so I can't say what parts you would need to swap over, would be possible to swap over, or you would have to custom fabricate.
Easiest route is to swap in a `01-`02 Pathfinder VQ35DE (whatever years it is for that bodystyle, is it `00-`02?), wiring harness, and ECU. This doesn't get quite as much stock power as the later VQ35DE's but due to the motor mount/block differences between the RWD and FWD VQ's, it's probably by far the easiest.
