VQ30DE "Tick Tick Tick"
Discuss topics related to the VQ series engine.
MaXimaSE
Car: 1998 Nissan Maxima SE
ok, so Im running a VQ30DE..
-124,7xx Miles-Sunoco 91 Premium / Mobil 1 Full Synthetic 10W-30-Automatic-New Plugs (Laser Plat Premium NGK) -New Fuel Filter-New PCV Valve-Idle Adjusted from 500RPM to 700-900RPM-Throttle Body was throughly cleaned..
When the car is at a full idle, even at normal operating temperature I hear a very rapid "tick tick tick" coming from what sounds like the center of the engine block. When I pull up on the throttle cable, the engine mutes It almost, but then soon as you let it go back to idle "tick tick tick" and Its fast too. I do not hear it from inside the car, only when Im outside of it.. or the hood is up and Its idling.
What could this possibly be, I don't want my motor to blow into smitherines when I just got her fixed.
Death By Thrash Metal
Car: Well, i am a liar so it doesnt matter
Well try posting in the Vq 30de/tt section (300zx section)... that will yeild better info... but i think for the TTs the buying guide said to listen for a faint ticking (vq30dett) and if the tempo is smooth then they timing is good, but if its not then well the engine has timing issues... or somthing like that...
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Light ticking at idle is considered normal for the VQ.Keep up regular maintenance and listen to see if it gets any louder. As you describe it, I wouldn't be concerned. If you start to find that the ticking doesn't fade with throttle, you may want to look into it further.
Death By Thrash Metal wrote:Well try posting in the Vq 30de/tt section (300zx section)... that will yeild better info... but i think for the TTs the buying guide said to listen for a faint ticking (vq30dett) and if the tempo is smooth then they timing is good, but if its not then well the engine has timing issues... or somthing like that...
300zx has a VG30DETT, not VQ30DETT.There are no US-market turbo VQ variants.
MaXimaSE
MinisterofDOOM wrote:Light ticking at idle is considered normal for the VQ.Keep up regular maintenance and listen to see if it gets any louder. As you describe it, I wouldn't be concerned. If you start to find that the ticking doesn't fade with throttle, you may want to look into it further.
Thanks, the ticking is isn't out of control.. I seafoamed the crankcase,gas tank, and the manifold.. Everything on the car is alright besides the stupid evap code
Q45tech
Research the less than stellar very common chemicals in SFOAM.
MaviMax
Car: 1997 Nissan Maxima SE 5spd
if your describing it exactlly how it is then you have notthing to worry about its normal i got a 97 max and it does it too my bro just bought the 06 max wit 14k and it does too so dont worry about it...
Return to “VQ30DE / VQ35DE / VQ35HR Forum”
