VQ30DE-K Engine swap
Discuss topics related to the VQ series engine.
DJBONFIRE
Car: 1995 MAXIMA & 1988 300ZX SS
Hi every one, i am trying to swap a 5th gen maxima engine into my 4th gen can anyone help with swap? or write ups thanks.
irax
Car: VQ35DER Powered S14.3
hey look that up on Maxima.org
but just to give you some info
your going to need
engine, trans, wire harness, ecu, nats, bcm, key, maf, intake and a custom exhaust manifolds.
Soravia
Car: 2003 Audi A4 1.8T
You won't need NATS and BCM if you go with VQ30DE from 1995-1998 model and put the DE-K manifold on top.
i30dvr
irax wrote:hey look that up on Maxima.org
your going to need
well ur not going to need all that for starters....i've done the swap. u dont need custom exhaust manifolds b/c they are indentical to the stock vq30. U can even use the 3.5 manifolds. u would use your existing transmission. The only thing you would take off teh 5th gen wire harness is the injectors clips b/c they are different. You just need to splice them in. your factory harness and ecu will work if you don't want to do a full rewire which is a pita.
pahaf
Car: 91 Z32 TT
but dont u have to change something on the cams?
Return to “VQ30DE / VQ35DE / VQ35HR Forum”
