dj-jumbles »
https://forums.nicoclub.com/dj-jumbles-u135141.html
Tue Nov 23, 2010 9:30 am
I don't actually have the DE manifold. All I received was the long block, so I don't have any of the old accessories.
Just as a note to others who might read this:
I've spent about 4 hours going through the Infiniti tech manuals and this is what I have:
The water flow will not be impeded by blocking off the intake into the water control valve that comes out of the block of the DEK. Granted it might cause some mild overheating in extreme hot weather (I like in Milwaukee, so I don't think I have to worry about it).
The DEK engine also has a water circuit that runs to the throttle assembly (???), so anyone looking to upgrade from a DE to a DEK needs to keep this in mind if they don't have the complete engine with all the piping.
What I've decided to do is use the DE long block and the DEK water outlet assembly. I'll block off the inlet into the "Water Control Valve" and remove the thermostat "valve" from the housing, essentially creating a straight circuit on the return. The thermostat on the inlet side will still be in place, so it should operate nominally. By utilizing the original outlet piping, I don't have to MacGuyver another branch off of the heater core assembly to supply the throttle assembly.
Thanks, tigersharkdude. I'll post back up my results after we start this piece up and let everyone know if this is successful. I'd like to dyno the engine to see what the HP output is, but that's not really practical. I think that as soon as I take it out on the road, we'll know right away if the power is in the DEK range over the DE.
Hell, if this works, anyone out there with a 2000-2001 Maxima/I30 that needs an engine swap would find the info useful I hope. I bought the long block for only $900 with $150 shipping and I've been working on it over the past week and a half (and working a more than full-time job), so with the rental you're talking about $1500 for the new engine. I don't even want to think how much it would have cost to have a shop do it.
BTW: you CAN take these engines out of the top of the car, it's just an additional headache.
