VQ30-VQ35 HEAD
Discuss topics related to the VQ series engine.
MaviMax
Car: 1997 Nissan Maxima SE 5spd
i want to put the vq35 head on my vq30... would it give my engine a little more power or no? i have a 97 max se 5spd...
DanCouga
Car: 1997 Nissan 240sx
I'm finding mixed answers on this one. I am guessing that FF VQs differ from FRs. I found that the headgaskets are the same on the VQ30/35 in the altima/maxima. But have also found on the same site different headgaskets for just the VQ35.
I searched for the CCs difference in the combustion chambers, but couldn't come up with anything. I think I have read that VQ35 has a larger combustion chamber, so that would lower your compression ratio.
In searching around I did find that there is a VQ30 head available that gives you a static compression ratio of 12:1 with a different ports and titanium valves. Couldn't find any links to anywhere to order it and only saw it mentioned in a few articles so it could be just some make believe part.
VQ30DET S13
Car: '89 240SX Coupe, '92 Maxima SE
DanCouga wrote:I think I have read that VQ35 has a larger combustion chamber, so that would lower your compression ratio.
You're correct. If you were to put vq35 heads on a vq30, it would give you a CR of about 8.5:1 which would be awesome for boost, but it would suck for NA. If you wanted to stay NA you'd have two choices. Get high comp vq30 pistons or buy these heads. These heads are basically vq35 heads with vq30 combustion chambers. You also would have to use the vq35 IM setup if you used the vq35 heads.
Coinage
Car: 2002 Maxima SE 6sp
If you are looking for a set of ported/polished heads i have a set, along with JWT C2 cams...
http://forums.maxima.org/showthread.php?t=551360
Return to “VQ30DE / VQ35DE / VQ35HR Forum”
