VQ swapped 240's
Krimlin
Hey guys, I was just wondering who all here has done or is doing a VQ swap and would be willing to give some advice on the swap, common problems and such.
Car:95' 240sx SE
Motor:2004.5 VQ35DE "High Rev"
Swap Kit from:VQSwap.com^I have head some good and bad things about thier kits, let me know if you have experience with it good or bad^
Bought the motor from a good friend as a long block that had been hydro-locked with one bent rod (he bought it from Nissan, and it was confirmed that the only problem was a bent rod in cyl. #4) I also got a helluva steal on it. It's no problem I'll be ordering forged internals for it within the month and sleeving the block shortly after that.
Still waiting to get a good condition transmission and I will be ordering the complete wiring harness in the next week or two.
Plans:Build for high compression, and make a good drifting application.
Projected Finish date range:01/01/10 - 04/01/10
Krimlin
Anybody?
s14derrick
Car: 1995 nissan 240sx
look in the hybrid section that should have alot of the info you are looking for.
Krimlin
thanks man! I'll try there and keep it posted here
Salem240
Car: '05 Pathfinder 4X4 SE
'98 240SX SE
I just posted up this week about doing a VQ40 in my zenki. The VQ40 from what I find is just a stroked VQ35HR. I'm not planning on doing the swap soon but I eventually would like to do this. If you do this swap please do a build thread. I will be following your progress closely. I know one thing for sure you will have to have a stand alone EMS that manages VVT also. Apparently the security system and engine control system are tied together so it would be a absolute bish to get all the stock harness, ignition and ECU to work right. I'm pretty sure I could squeeze the extra deck height of the VQ40 under an Origin cowl hood. The VQ35HR has a different intake setup(dual) than the VQ35DE, I'm not sure how the clearance is for it. But the biggest advantage with doing a VQ swap is that it is lighter an more compact than the RB. You can nearly get 80% of the VQ's weight behind the strut towers for a better balanced chassis.
here is a link to the VQ40 topic I created. Check it out, it has some info on there too .zer...240sx
Keep it posted
offroadbob
Car: 96 240sx, 84 720 4x4
here you go all you will ever need to know and more!
zerothread?id=207033
