Slow down there, young buck. It was cheap for those guys because they knew what they were doing. I.E. They swapped in FWD VQ35's instead of RWD VQ35's.myl3s wrote:thats for the help, and understanding...hahahah5Gs for the VQ swap isnt so bad i thought it was gana be more
No, the 5g's does include that stuff. But it's only going to be in the range of ~$5g's if the use the cheaper FWD motor. The RWD motor will cost much more.myl3s wrote:so wat you guys are saying is that the 5gs does or doesnt include the intake manifold, mounts, etc.?how much do u think the average shop would do it for?Cus i had my rx7 ls1 swap put in for 500...not including motor...obviusly
From the thread: zer...240sxirax wrote:ok so what is required to do this swap you ask?
FWD VQ engineRWD intake manifoldRWD exhaustRWD upper and lower oil panEngine/dash wiring harness from the VQ car you got the ecu and bcm fromNVIS or NATS with key from the fermentationed car My mounts which use the 300zx motor mounts and trans bushinga drive shaftRWD vq35de transmission revup or non revup doesnt matter just needs to be the same generation of VQ since HR,DE,and VR trans are not interchangeable. RWD waterpipesGreffin RadiatorMy shift linkage kit or the guy from vq240z.com's kit he is selling on hybridz.org. A custom exhaustAn ABS source IE an ABS diff or abs spindle to get a Speed signalDakota Digital Converter to convert ABS pulse into speed pulse. To 'smog' the car or ref it and get it BAR approved you will need the catalytic converters from a RWD plat formSmog equipment from the car you took the ecu/bcm/nats/key fromyou may need an IPDM depending on the ecu you use. You will need to upgrade the fuel pump to a 300zx or Q45 or a walboro 255lhrYou will need an aftermarket FPR preferebly a nismo or aeromotiveyou can use a FPR off of a VQ30 but you will need to modify to fitYou need a DBW gas pedal obviously if you use a DBW VQ ECUthe one from the z33 and the 5.5 gen and 6th gen maxima work
I don't agree. Engine choice is a pretty personal decision IMO and what makes you happy may not do it for the next guy. The LS1 is great and all, but the motor and transmission are both pretty heavy. And the swap is a shoehorn job.GODCHSR wrote:LS1 FTW
Sorry I had to say it becasue the LS1 pwns all other swaps.
The LS1 only weighs like 200 pounds more over the stock KA and your getting double the cylinders.simmode1 wrote:
VQ35 strengths:-some ppl don't like interbrand swaps, -more displacement than CA, SR, KA, RB and 2jz-6spd transmission sourced with ease.-Good horsepower/torque in stock form-less wieght than KA, RB, 2JZ, and LSx (we're talking like, 200 lbs here )
LSx is great. But peak HP numbers don't matter to some ppl. 350hp with good power under the curve is enough for me and is easily within the VQ abilities. Plus I wouldn't want to increase the wieght in the front of my car trying to accomodate an LSx, which is overkill most ppl.
And i agree with that as well.One should consider all options,pro/cons before dropping that kind of money on anything.Also if your haveing to worry about emissions then pretty much the VQ is your only choice really.simmode1 wrote:
And the LSx transmission is notoriously heavy. I'm not hating on the LSx. I'm just saying that writing off an award winning motor like the VQ is silly.
My bad... I was just being annoying.simmode1 wrote: I am seriously getting sick of hearing about LSx swaps. Not everybody wants that. The OP has already been there and done that. He even had an LS1 in his RX7 and didn't even care to ask about it. GTFO with the LS1 talk...
