VQ Powered 3rd Gen
DragonMaxima
Car: 1990 Nissan Maxima GXE
I decided that I want to run a 4th or 5th Gen Maxima VQ series motor. Leaning toward the 5th gen because of larger power output, but 4th Gen motor easier to find.
I know fab work will be in order, but I want to know who has done a swap like this already.
I want to know what all will be needed to do the swap. (Wiring, hoses, mounts, ect....)
My Maxima is running up on the 250K mark and I want to give it new life. My motor runs well, but I want to drop something in that not only has significantly less miles but also is more powerful and is easier to find parts for.
Any and all help will be accepted.
Thanx
maxhopper
Car: 02 Maxima SE 6spd
There's not much difference between the 3rd and 4th gen motors as far as torque and hp. Unless you (or someone you know) is a wizard at wiring and fabrication, I would strongly discourage you from swapping to a 5th gen 3.5L.
Why not just buy a JDM VG30DE from http://www.soko.com. and install a turbo?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
The VG30E only makes 160 hp. Even early VQ30s made 210. Unless you're comparing the VE, which is still not really comparable due to being limited to it's upper rev-range for usable power while the VQ is most certainly not, there's a world of difference between 3rd and 4th gens power wise.
I know the VQ has been done, but I haven't really looked into what's necessary. I've decided to take a slightly different route by making a "VG34ER" or maybe even bigger...The VQ third gens I've seen also have 4th gen transaxles, which makes sense. If I were to do the VQ swap, I'd go all out with a 6th gen 6 speed on a 4th gen VQ30DE.
I think the VG30DE suggestion is be the best option. Even that won't be total cake, though, as the VG-E and VG-DE blocks are not identical. Mounting points (both engine and accessory) are different. Heads from the VG-DE will NOT work on a VG-E. I'm not sure if the FWD transaxle will mate to the VG-DE without modification either.
internetautomart
Car: more than you!
currently 94 u13 (electrical gremlin), 97 u13 (incoming)
Boy, talk about some disinformation1. the VQ30DE starts off at 190hp not 2102.a VG30DE will not physically fit in a third gens engine bay with serious cutting and welding.
if the car has a VG30E (all 89-94 GXE and 89-91 SEs) then the easiest route to more power is a turbo.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
internetautomart wrote:Boy, talk about some disinformation1. the VQ30DE starts off at 190hp not 2102.a VG30DE will not physically fit in a third gens engine bay with serious cutting and welding.
This thread is not about what is easiest. This thread was about swapping a VQ30DE into a third gen. You're right about the horsepower, though--I don't know where I got 210 from.Also, point #2 has already been noted in my posts. I mentioned the need for fabrication. I never said it would fit without modification.
The turbo option was not brought up, as the original poster stated that he wants to replace his stock VG, not make more power with it.
If you registered just to pick apart my helpful posts, you might want to hit the search button and find out for yourself that we've covered much of this already, so a lot of the "missing" information is missing because it would be redundant.
Welcome to NICO.
internetautomart
Car: more than you!
Points taken.
I guess your definition of fabrication includes moving structural pieces too :
my post was not meant to pick apart yours, I'm just too used to people wanting to do this motor swap or that and researching it nearly enough to realize just what is involved in doing it.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Definitely appreciate your input.
I should apologise for being so hostile. That's not how we do things around here, and definitely not "me". It's a monday morning after a LONG night at work...I should have just let it wait until I was free of the stress of the office. Sorry about that.
As for my definition of fabrication, yeah, by that I mean altering/moving structural components.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You maxima guys need to focus on "straightening" your engines... If your engine wasnt sideways in the engine bay, then you could be taking your maxima's sideways!!!
/troll
internetautomart
Car: more than you!
MinisterofDOOM wrote:Definitely appreciate your input.
meh, impulsive responses can help add to the fun of a forum.
Brian - Good to see you here!
Let me know if you'd like to offer a hand here in "Maximaville"...
internetautomart
Car: more than you!
I'm always willing to lend a hand.especially if you'll put up with my blatant self promotion
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
internetautomart wrote:especially if you'll put up with my blatant self promotion
Speaking of which...Do you have access to canadian third gen seatbelts? I've been thinking about getting rid of these blasted power belts...
internetautomart
Car: more than you!
MinisterofDOOM wrote:Speaking of which...Do you have access to canadian third gen seatbelts? I've been thinking about getting rid of these blasted power belts...
from my understanding we (USDM) don't have the mounting points on our cars for the shoulder of the canuck version.
I may be wrong though.
BTW I'm more stock replacement mechanical parts than body parts
DragonMaxima
Ok guys, here is my reasoning for wanting a 4th gen motor.
1. The engine would have less miles, and more stock power, not to mention a second cam with a greater opportunity for power options.
2. This motor was offered for more years and would be easy to find. Also more companies make parts for this motor as opposed to the 3rd gen motors.
I understand the need for fabrication. i know there is no way to swap a motor in a car that shouldnt be there without making changes.
after talking to a few of my friends, i think that i am going to back to my original plan.....and make it rear wheel drive.
I have a whole group of friends who have graduated from Wyotech in High Performance engines and Chassis fabrication.
He tells me that we can do it pretty easy.
so i think i am going to run either a CA18DET or go balls out and make it an american Cefiro with an RB26DETT
I miss drifting, so thats the new goal.
audtatious
RWD 2nd gen has been done with a V8. Might as well do a 3rd gen.
internetautomart
Car: more than you!
meh, making it RWD isn't that hard if you got welding skills and patience.I planned it out with another guy before , but it was decided to forgo RWDing a 3rd gen, not worth it.
DragonMaxima
Yeah all my friends are certified welders also. My biggest thing will be finding a rear end of similar dimensions to fit under the car.
It will be expensive, but it will be worth it to me.
Chris92SE
Car: 2017 Infiniti QX30
2003 Nissan Pathfinder LE
DragonMaxima wrote:Ok guys, here is my reasoning for wanting a 4th gen motor.
Yeah, I am new to this site, but not to Maximas.
If you are a good welder/fabricator and have a lot of extra time, than maybe you could try a swap. It's not impossible, but a pretty advanced job. It's not like putting an SR20DET into an s13, it's much more complicated.
However, there are virtually no similarities between a VG30E and a VQ30DE and how they would fit into a 3rd gen.
You wouldn't just need an engine, but almost an entire donor car. The electronics are all different, including the ECU and speed sensor on the transmission. You would need an engine, transmission, axles, ECU, dash (or at least the speedo) along with a complete wiring harness.
The motor and transmission mounts are also different, so all of that would have to be fabricated.
I have seen one car that had this done and it took a lot of time and fabrication.
Honestly, if you were going to do this swap, you might as well do a 3.5L. It has a lot more power and potential. 4th gens with the 3.5L swap run in the 13s naturally aspirated and those engines are even newer with usually very low miles.
I am not going to comment on a rear wheel drive conversion. That is Jesse James/Monster Garage stuff. If you can do a job like that we should be asking you all of the questions.
audtatious
Chris92SE wrote:I am not going to comment on a rear wheel drive conversion. That is Jesse James/Monster Garage stuff. If you can do a job like that we should be asking you all of the questions.
Well, you did comment, but I agree. If you are going to fab RWD in a Maxima, you might as well "shoot the moon" and build an ATESSA-based AWD Maxima instead of settling for a RWD setup.
Chris, welcome to NICO. Bit different "feel" than the .org
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
audtatious wrote:If you are going to fab RWD in a Maxima, you might as well "shoot the moon" and build an ATESSA-based AWD Maxima instead of settling for a RWD setup.
Unless you don't want AWD...
audtatious
The most common "conversion" you hear about (from a drive wheel perspective) is converting a Maxi to be like a GT-R. RWD is only 1/2 way to the "holy grail"
internetautomart
Car: more than you!
I for one would rather have the RWD only on a project like this.of course i'd take the easy way and just mount the motor in the trunk
seyath
Car: 2004 Maxima SE, 6sp, black leather. 1991 240SX, 5sp, grey leather.
Hum.... a lot of familiar faces from other forums :-)
audtatious
internetautomart wrote:I for one would rather have the RWD only on a project like this.of course i'd take the easy way and just mount the motor in the trunk
Keep the front motor and add another in the trunk. Like the 10-second Tibby project
internetautomart
Car: more than you!
audtatious wrote:Keep the front motor and add another in the trunk. Like the 10-second Tibby project
yeah, but I worry about the weight penalty.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Plus, two Tib motors still don't equal one VQ.
audtatious
Pull the VQ out and do the JATO tail light mod?
