ZGadson »
https://forums.nicoclub.com/zgadson-u56225.html
Sat Jun 09, 2007 3:47 am
Problem: Apparently the Bose systems in our cars have a bass saver function that turns the bass down as you crank up the volume- in an effort to not have a chernobyl repeat when the speakers blow up I assume.
Question: I have my woofer amp connected to the rear speakers (I spliced into the rear speaker wires where they connect to the Bose amp) because that seems to be the only simple way to do it without ripping the dash apart. Is there a way to connect the woofer so that it doesn't almost turn off when the volume is higher?
Answer: Anyone?
EDIT: My stock Bose woofer still sounds great, but it rattles like it's got pennies stuck in it. Obviously, I've looked, but couldn't find anything. Anyone got a fix for this?
