voltmeter gauge help
miracleboi123
Car: 93 s13 coupe
ok, so after my battery drainage mystery issue was solved on my s13, i decided i want to invest in a voltmeter gauge which ill install on the a piller. anyways, cos of my past charging issues, if the car was running i want to make sure its actually charging too, i found a good deal for an autometer voltmeter gauge for 30.
all i want to know is where do i connect the voltmeter to, to let it read how much is being charged.
and what kind of wires will i need?
please help all info is great! =]
SirSilvia
Car: Sold both my babies
I didn't find it necessary to have a gauge pod just for voltage. so i got one of these if you are doing a pod then you can hook it through the cig lighter lead or any other 12V lead in the car. I use mainly 18 or 16 gauge wire for this kind of stuff.
w0nderbr3ad
Car: 1990 240sx with ka24de swap
Its only 12v source and ground. You can use anything from 14 to 18 gauge wire.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
I used the ignition wire as my 12v source. Turn key, gauge reads. Simple, I used the piggyback wire splices.
