voltage stabilizer????
g35sedanlover
Car: 03 Infiniti G35 Sedan
Do voltage stabilizers do much of anything or are they similar to the tornado intake things that are just a gimmick? I have seem some JDM ones on e-bay for like $25 shipped...
g35sedanlover
anyone run these?
TDS
Car: 2008 G35
There is a current magazine out that did dyno runs on a g37. I believe they added intake, catback, hiflow cat, and the apexi voltage stabilizer (~$125). The total increase was 25-30whp. The increases overall were minimal for the voltage stabalizer (1-3whp depending on the rpm range), while a high flow cat gave the G a 14whp increase alone! I wouldn't trust the ebay brand because the wiring is probably weak. It's like using stereo/speaker wire in your engine bay for grounds.
joe603
Car: 2014 Durango R/T
Voltage stabilizer...you mean grounding wires?? Got a link?
rn79870
Car: 2008 G35 & 2005 Vette C6 vert.
Joe, I think he is referring to this one
http://www.automotivelightingu...=1029
I've seen the same one advertised someplace else for about $130
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
joe603 wrote:Voltage stabilizer...you mean grounding wires?? Got a link?
you can get the voltage regulator seperate. it makes sure you have the right voltage to the spark plugs and supposed to make grounding better.
I'm a little skeptical about this, prolly cuz nobody has tried it yet.
joe603
Cool, thanks! I don't think it would be worth it unless you have an aftermarket ECU...
tollboothwilley
i think it might only make enough difference if you are running FI. Other than that any advantage.
Grounding wires alone do all the above, just no monitoring system.
