Voltage question RB20 w/ quest 125 amp alt.
pepegurr
Car: 89 coupe w/ rb20 swap - RIP but making a comeback
86 Porsche 944
92 FZR400 - Track Slut
95 240sx-se - Newest member of the family- DD
What should the proper voltage be for the rb20 with quest alt? Mine sits at roughly 13.6 running but drops to 13.0 with all accesories going. This seems a bit low to me and its seems to be affecting ignition under heavy load(i.e. sputtering). I have a brand new battery with a brand new 125 amp quest alternator.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
That's too low. Should be a solid 14v.
pepegurr
86 Porsche 944
Thats what i thought as well but im not sure what to do to bring it up. i think im gonna check the voltage at the alternator tomorrow to see if its a problem there or something on down the line. hopefully its just a loose connection or something .
Carl H
i see a solid 14.5v damn near constant.check connections...also check with a 'real' multimeter.also depending on where you have your gauge wired can also dictate what you see...a friend had a voltage gauge tapped into the ignition harness and it read 13.2v but when he ran it directly to the battery it read 14.5v.food for thought.
pepegurr
86 Porsche 944
Thanks carl i was hopin you would pop in. i plan on using a set of fluke multimeters, i refuse to buy cheap meters , too much to go wrong if they arent dead on. Im getting my reading through my SAFC.
