voltage not stable?
sXi
Hi, I've noticed this. my run idles normal. but when I use any of the electronics on the car. the rpm needle drops about 150 - 200 rmp. for example, when I use the power window, the needle drops until I release the window switch, it will go back to normal.
why is that? or is it completely normal act?
thanks
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Is there any oil in your coolant?
Any knocking when the RPMs jump around like that?
Have you ever overheated or run the motor without oil?
How much woodk could a woodchuck...
j/k...
It's completely normal.
More load on the eletrical system makes the alternator work harder to produce voltage/amps...so the idle suffers a little. The A/C compresosr will do the same thing, excpet it has a backup idle control motor to help smooth it back out.
- Brian
