SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Mon Mar 07, 2005 10:53 pm
OK I have test fit this setup on my car so it is safe and sure to fit, albeit a bit "conservative" (all my recommendations are) according to my nico brethren...
Front: 17x8 +35 215/45-17
Rear: 17x8+35 245/40-17
This setup sits so nicely and without complication under the s13.
The A and B denote the size (depth) of the bolt pad as it reaches farther toward the back of the wheel. This alters offset greatly. Take a look at the backside of a wheel from a Lancer EVO that has Brembo kit. The back of the spokes are extremely flat, but the bolt pad reaches FAR into the wheel..
The wheels with Super High Pad fit the big brake kits. Rays makes it very easy by telling you exactly which wheel will fit over which package.
Rays lists pad types as:Super High Pad Type(offset Z)High Type (offset A)Mid Type (offset B)Low Type (offset C)
Super high clears big brakes, high type clears some, mid type not so many, low type "test fit first".
Now if only they could speed up build time... Rays builds one wheel style at a time. If they're doing GT-C this month, we wait for LE37 until Rays decides to build more...
Hope you found an answer to your question somewhere in there....
