Hey there welcome to the dark side.
Time to move past old vtec to VVEL, congratulations.
Is there a protruding cover that says COMPACT FLASH in caps?
If there is indeed the cover installed take your first put your nail against finisher and gently pull forward. It really should not take much effort to free the cover.
The voice commands in the G37 are pretty basic. You are only able to activate the climate control.
Yes, there is a reason for it,
Yes, I too think that it sucks.
I have been dealing with the variants of this system for a while. The best advice I can give you is check out the updated manual especially for the voice command (link below) and spend some time going through the voice adaptation mode if you plan on using the system. It will give the car the time required to learn how you speak and you a chance to learn how the car wants to be spoken to.
http://www.infinitiusa.com/pdf/techpubs ... lement.pdf
http://www.infinitiusa.com/iapps/techpubs
Enjoy rear wheel drive.
