vlsd trouble
snowdrifts13
Car: 1991 nissan 240sx
i did search i didnt find anything so heres my problem. i put an infiniti j30 vlsd in my 91 240, fit in good not problems until i started getting bad wheel bearings. the back right axle is to long and sets my camber off so it makes my wheel bearing go bad(axle bolt torqued to spec). also wehn i bolt everything up the the driveline where it goes into the transmission has to be pulled out about a half inch to make it fit tight to the diff, so fluid leaks out my transmission. i always hear everyone say throw the j30 diff right in no worries, but it doesnt fit right. and yes i did swap the diff covers. tell me what im doing wrong. thanks
Emperor_Tha
It should bolt up with no problem. All u need is abs driveshaft.
monza350
Car: 92 Nissan 240sx SR20DET
swap the j30 gears to your 240 case..... if u still have it
snowdrifts13
but if i do that the axle will still be to long, is there anyway i can swap the guts out of the j30 case into the stock case and use the stock output shafts the 6 bolt so i can use the stock axles?
