USDMSTALKER wrote:burn tire if there is two marks you have one if one mark you don't
jab11185 wrote:by the way...does anyone know if the HICAS vlsd bolts right up to other s13's?
the output flanges are the same. 2 bolts per point (total 6). That's where the similarity stops. V LSD outputs are longer than open diff outputs, so you need to make sure you have the V LSD outputs if you end up swapping in a V LSDjustmerging wrote:
HICAS VLSD will bolt up but you need to get the shorter driveshaft because of the ABS that HICAS models come equipped with. I'm not sure, but I think even the output shafts are the same? A little help (I'm not the expert cause my car came with one already on it)?
