rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Tue Feb 03, 2004 12:16 pm
First off, a quick search would give you TONS of great threads with all the answers you need.
If you order a JDM VLSD, the output shafts from your car will work. That is the only way to use your output shafts. Now, if you get a R200 (off of a non turbo Z32) that has the same gear ratio as the 240SX, but 5 bolt halfshafts (stronger) A J30 VLSD will work, but the gears different, and you will lose acceleration, but gain top end. So there ya go. As far as drive shaft, the stock shaft will work if the diff came from a non ABS car IIRC, but don't quote me on that.
