vlsd
mike240sr
Car: 1991 240sx se with sr20det
how do you find out if you have a lsd in you car
because i just bought a jdm s13 rear end for $275
c-rad
Car: 1991 Nissan 240SX w/CA18DET
This question has been asked a billion times. If you have an S13, and its not a HICAS model...then you don't have one. If you have an S14... it came with the ABS package on SE's.
Juujai
you can get a used 2-way for pretty cheap about 400-500. i dont really support the vlsd its pretty expensive for what it does. but whatever rocks your boat
unless you get lucky getting it cheap
mike240sr
is 275 for the entire rear sub frame
axles hub everything
SmithSR
Car: 240sx
5 bolt flanges?Find the sticker that clearly says VLSDTurn one output flange. Done the other side flange turn in the same direction?
