VLSD S14 K's into 95 240sx
Nissan-S14
Car: 95 Nissan 240SX SE
Will a VLSD from an S14 K's model fit the US 95 240sx?
Ace
Car: S14
It should just make sure that the S14 SE axles have the same pattern as the output shafts on the VLSD. I bleive the S14 has a three prong look with two bolts on each "prong". If they aren't the same then you would need Silvia K's axles if you wanted the K's VLSD that much.
