VLSD question
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
if i bought a VLSD from a J30 or 180sx and it had the 5 bolt pattern output shafts, could i remove the shafts from my open diff and use those in the VLSD or no? Thanks.
sjbsuperman1425
CA18DET
anybody?
s13beast
Car: 94 5spd silvert S14 SR
91 hatchback dd
This has been covered alot. Im 89% sure on...no.
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
White Comet
Car: fc, s13 and mazda6, Sierra
s13beast wrote:This has been covered alot. Im 89% sure on...no.
i'm not 100% sure what the op is asking but it sounds like yes.
op- you have a vlsd and want to swap in you regular non lsd output shafts to use your stock axles, correct? i'm almost certain this wouldnt work with a j30 diff, but i have a vlsd out of a 97 180sx. i swapped the guts of the vlsd into my stock diff housing and used stock axles and output shafts. so find out exactly what vlsd you have to be certain.
s13beast
91 hatchback dd
He said he had the j30 with the 5 bolt pattern. Im pretty sure your stock open dif shafts wont work In the j30 housing. your best bet is to get some axles for 90 bux at autozone. thats what i had to do for my z32 diff.
White Comet
he said j30 OR 180sx that why i broke it down into an answer for each scenario
sjbsuperman1425
CA18DET
thanks guys that helped alot.
