VLSD...One-way..Two-way??
SoCalS14
Car: My car...duh
I searched and I only found one answer to this question...most threads deal with application rather than specs...
Is the factory VLSD a one-way, 1.5 or Two-way LSD?
Anand
Car: 95 Nissan 240SX
VLSD is one way...
SoCalS14
Car: My car...duh
Hmm...That is interesting beacuse I found a post that said it was two-way. I can see why, if the lock-up is dependent on Fluid tempreature...it should lock in either direction...any comments?
SRdave240
Using that logic, all LSD's would be 2-way.
SoCalS14
Car: My car...duh
true...hmmm...somehow thi sis not settled in my mind...
sil80drifter
Car: 1990 240SX Hatch
sooooo are all VLSDs 2 way? because i can see hwo the cluthc type ones would be one way since direction would matter.
sil80
C-Kwik
It is a two-way. It provides the same lock-up in acceleration and deceleration. The VLSDs provide resistance at all times with the only changes in lock-up only occuring with changes in fluid viscosity. The VLSD does not differentiate direction of travel. Mechanical 1.5 and 2 ways always have some resistance, but during acceleration and deceleration they actively lock-up more. 2-way does it equally in both directions and 1.5 does it less during decelration. A VLSD is essentially always active. the torque transfer in both directions is potentially equal.
SoCalS14
Car: My car...duh
Na...see I just was wondering whether Nissan VLSD's are one way or two way, and I have gotten different answers...One post said it was a two-way...but I thought that is to good to be true...Then a posted this thread, and someone has said its one way...I am just looking for some consensus..
SoCalS14
Car: My car...duh
Thank you C-Kwik...I knew there had to be a difference between the mechanical and viscous...Then my logic was aptly applied...
corn322
Car: 1993 240sx
I have a couple questions...1. how big is the stock viscous coupler in the VLSD2. how big of a viscous coupler could you fit in there? I can imagine a bigger one with plates closer together or something could have pretty good locking characteristics.
