its a vlsd... it'll do that.
like liquid_cool said, it works by the diff fluid. Under heavy load it'll lock. You won't be able to tell just cuz one wheel is in the air, you're putting little stress on the diff just going up your driveway, you won't be able to get it to lock with that little pressure. That's why its called "VLSD". V for viscous (not vicious).. it uses the viscosity of the diff fluid to do its job
if you want a better lock, get a clutch type diff or weld an open diff.
r3v_v3ng3 wrote:vlsd has to be in certain temps to lock up. it is liquid inside so when its hot it grabs more
I think you have this concept backwards. It becomes useless after its past a certain temp (basically turns into an open diff).
I have a j30 vlsd on my s13... I can enjoy like 3 hours of drifting (if that.. maybe less?) before I start noticing one wheel not locking. Then I'd have to let my diff cool down for a few hours before hitting it back up. Lets face it, vlsd's were intended for the spirited driver, not the daily racer.
