VLSD HELP!
Vinchenzo
Car: 1990 Hatch
1993 Coupe
Hey guys. im installing my 300zx differential in the 240, i have my j30 axels and most of the bolts.I know i need 12mm x 1.25 x 85 mm for the front mounting points of the diff, but i cant find them any where.
i was wondering where you guys (who have swaped these things) got your bolts from
thanks in advance...
heres the website i got the info http://ka24development.com/vlsd.html
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
the dealer? Boltdepot.com?
Vinchenzo
Car: 1990 Hatch
1993 Coupe
Found 12mm x 1.25 x 80 mm & 12mm x 1.25 x 90 mm but no 85mm as called out by others... Washers perhaps??
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
Don't make up lengths with washers. Do you have a local Fastenal? If so, go in there and tell them what you need, they can probably get it.
M12 x 1.25 x 85mm
I'm having a little trouble seeing where you need an 85mm bolt...
Vinchenzo
Car: 1990 Hatch
1993 Coupe
From the link above:
"You will also need 2 longer mounting bolts for the S13 chassis, and 2 large washers for the front mounts...to be used with the large bushings on the front mounts.
They are M12 X 1.25 thread/pitch, 85mm long. "
My dad works with a company that competes with Fastenall. Great Idea ... Thanks.. I'm also going to try the dealer in the a.m. for stock bolts for 300zx.
Wish me luck...
speedeast
Go to my thread and see what I did when I installed my differential, might help you out a little. I'm not real familiar with the 300zx diff, but I had to modify my q45 diff.
It's in my signature.
crakin
Car: 1996 240sx s14, 2008 Chevrolet silverado crew cab,
2011 Suzuki gsxr 750
just cut the bolt if it is too long and run a die over it to ensure that the threads are still good they don't fab bolts that are 3" long any diff than 1.25" also us lock-tight. just grind it down carefully or use a band-saw. or a hack-saw but just be accurate and don't drink heavily before.
speedeast
crakin wrote:just cut the bolt if it is too long and run a die over it to ensure that the threads are still good they don't fab bolts that are 3" long any diff than 1.25" also us lock-tight. just grind it down carefully or use a band-saw. or a hack-saw but just be accurate and don't drink heavily before.
or you can just thread a nut on, cut it, clean it up a bit, then just thread the nut back off... lots of options.
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Dattebayo
The answer is: You get them off the 300ZX that the diff came from.
Seriously, no one ever thinks about the fact that you might need the mounting hardware that goes with the diff when they get it from the junker.
Modified by Dattebayo at 4:23 AM 4/5/2010
