VLSD Help
BMAR240SX
Car: 1993 Nissan 240S Coupe
I purchased a "s14 5 bolt vlsd" yesterday, i checked it out looked good etc. I know i have to swap the rear covers but I does anyone know if this vlsd has abs and if i have to get a abs drive shaft. Also can someone explain wtf this means 1/94+ J30 VLSD
Yea yea yea i am searching but some stuff just isn't making sense. Hung over from last night and to wake up and find info on a diff isnt fun
RCA
BMAR240SX wrote:I purchased a "s14 5 bolt vlsd" yesterday, i checked it out looked good etc. I know i have to swap the rear covers but I does anyone know if this vlsd has abs and if i have to get a abs drive shaft. Also can someone explain wtf this means 1/94+ J30 VLSD
What is a 5 bolt VLSD? What is 5 bolts? The LSD pumpkin should have 4 bolts (that connect to the car's rear subframe) but some input shafts have a 5 bolt pattern. But 240SX's have a 6 bolt pattern.
You will know if it is ABS if it is longer then your current LSD pumpkin or if there is a sensor on the pumpkin or a place for a sensor. Also if it is ABS dont get a J30 driveshaft get a steel one piece or an aluminum.
Maybe it means 1994+ J30 VLSD
ALSO being "hung over" or "drunk" isn't an excuse. Looking up info sober or drunk isnt fun.
Enjoy & Merry Christmas
BMAR240SX
Its an s14 diff there for it has only 2 bolts that connect to the subframe there for i must change the rear cover to bolt- on to my s13. I will check out what you said about the abs sensor. The diff has a 5 bolt pattern on the where the axles go there for i would lke to know the correct years of the j30 that will fit the diff.
Anyone know what this means 1/94+ J30 VLSD. I was searching and the 94+ are all bolt thats why i am still lost
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
A 5 bolt means the axles, as opposed to the 6 bolt stock axles. Your VLSD which came from a J30 (because its 5 bolt) does have ABS. Side by side its about an inch longer because of the ABS speed sensor located at the input shaft. If it does have the ABS sensor just leave it in and cut the wires.
You can swap the covers and put it in, you should have enough driveshaft play to make it work without needing an abs driveshaft.
I just took these pics for you, I just happened to have them sitting side by side
This is side by side the left is a J30 5bolt. Right is the R200 from my S13 (it has a Cusco 1.5 way LSD in it, and a Z32 turbo 3.69 ring gear but I blew it and made it an open diff). non abs with abs 6 bolt 5 bolt
Modified by OutToWinPAHC at 3:51 PM 12/25/2008
BMAR240SX
OutToWinPAHC wrote:A 5 bolt means the axles, as opposed to the 6 bolt stock axles. Your VLSD which came from a J30 (because its 5 bolt) does have ABS. Side by side its about an inch longer because of the ABS speed sensor located at the input shaft. If it does have the ABS sensor just leave it in and cut the wires.
Either the J30 diff looks exactly like the "s14 jdm one" or i got ripped my diff looks exactly like that. I also believe the numbers are the same R2______
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Its just a J30 rear, not a s14 because its a 5 bolt. Just swap covers, install with axels and call it a day it will fit.
BMAR240SX
There are some pictures is the cover the same as your j30
jeff420
Car: too many to fathom
looks like a 93 j30 rear end someone pulled from a junkyard. you'll need axles. the 95 j30 rear is a direct bolt in after swapping the rear cover.
BMAR240SX
Is it only the 95 axles that fit?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
1993 or the early part of 1994 J30 Axles. yeah thats a J30 rear. all you need is axles.Can I ask what you paid?
