VLSD gear oil
jab11185
Car: 1992 Nissan 240sx
what's the weight of the gear oill used in the vlsd's that came stock with HICAS s13's? or is there a better kind of oil?
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
I think I'm running 75w90. try searching. There is a lot of info hidden behind that red rectangle.
PapaSmurf2k3
Site Admin
im running 80w90 lucas oil. so far so good.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
use GL5 fluid.
DO NOT USE LSD ADDITIVE IN A VLSD DIFFERENTIAL!!!!
the viscous coupler is a sealed unit and does not require special additives. the lsd additives are for clutch type diffs. they will cause unneeded wear of the ring and pinion.
