VLSD ... again
nisssan-drive
Car: 1993 240sx
The vlsd has fluid packs,right so. I was reading that while drifting with the vlsd it will start to performe porly do to the fluid packs. For example a guys says"after i finished drifting my left tire was completly screwed while the right one was still okay.That is almost exactly what i read from a different forum . Is this true?
Slappy
Car: 1993 240 sx coupe
onosqv
Car: '92 240sx Vert
Yes...
The problem w/ vlsd is that most of the ones ppl run are 1xx,xxx miles, which means they won't perform as well.
Also, because it's viscous, one wheel will still engage before the other one (the time it takes the other one to engage is dependant on the condition of your vlsd).
Another problem comes in after drifting a lot on a vlsd, the diff will start to overheat & no longer engage both wheels... of course, most beginners don't have this problem.
That being said, there are still plenty of ppl who can drift just fine on vlsd... one tire wears more than the other? start drifting in the other direction
You should really search... it's all been covered to death.
nisssan-drive
Car: 1993 240sx
well thanks i am sure it will do just fine for me until i can afford a Kaaz.
1sikS13
Car: 1992 S13 240sx
mine went to hell i had a buddy weld it
