David Steele wrote:I'm sorry but you are very off 700rwhp KA with big heavy steel rods will destroy rod bearings with continued use in a 4 cylinder, that turbocharger also it's not suited for it 550hp isn't even that turbos range it can do over 900whp that is not practical on a little 4 cylinder.
And as for the quick spool valve, its very off topic but it's an undivided manifold on a divided turbocharger making the area smaller. Keep in mind that thing has a horrible power band to begin with, if it were a true 240 degree exh separation it would do a a lot better on a divided housing.
I can't trust you about mid range? It's not possible on those turbochargers unless you are over 4 liters and well designed turbo system. Midrange isn't a downshift away let's sound practical here. I mention 2 liters because the KA24 is a 2 liter engine 2.4 2.5 2.6 2.7 2.8 = still 2 liters I was being ethical and I wasn't being exact with that, but in laymans terms in the 2 liter range.
The KA24DE is a pretty normal engine there really isn't anything incredible about it, the SR20 and the VH are much better designed and they were designed after each other. Just because you haven't seen a KA crack doesn't mean its BS the RB series engines had issues cracking and these weren't extreme power levels, that's been revised somewhat to cope with the issue however an inline 6 has much better balance than a 180 degree 4 cylinder. however I'm not sure what reason you hold for calling bs on block cracking I'll have you know I come from the 4g63 family that iron block has been through more than any ka24de At extreme power levels they crack its not like everyone will report that there is a reason why the fill the blocks when exceeding 800whp hell 700whp can net 8 second ET's in a DSM.
There is also another thing I'd like to bring back up you want a 700-800whp 4 cylinder street car ONLY and now you want all motor 5 liter v8 no power goal said but its gonna be a track/street car this sure sounds ''a** backwards''.
I appreciate you determination, but dude seriously its ok... everything will work out. I will post videos as well. Its not impractical, impossible or silly lol. You don't have to believe me, people don't believe what they don't understand. Ignorance and negativity is the general morale on most automotive forums.
Power goal for the VH45de is around 300-330rwhp. Why does it matter what the VH45DE makes? I stated i don't need 800rwhp, so apparently its not a drag car, and you don't need that kind of power to drift or to race in certain classes for SCCA lol. Just saying...
The ka24de will be fine at those power levels, its been done many times, and yes the 4g63 is an amazing 2.0 liter engine block, i'm sure John Shephard and Brent Rau can attest to that. And no chit a 700awhp DSM could net 8sec quatermiles, dang I would hope so its all wheel drive lol.
The S372 will work just fine on a 2.4L even on 15psi,The compressor map on an S372R starts at 15psi and I will be running either a .90 or 1.10 a/r with the quick spool valve. The lead tech at Bullseye power stated that I would be fine with what i'm doing lol. I do enjoy your input though, as your above statements will be proven wrong, i'm sorry but its the truth. I'm going to run a 93 octane pump gas tune ranging from 15-17psi or whatever psi that will be maxing out my setup on pump gas. Hopefully I make around 550rwhp or more. THEN... I will have another tune setup for race gas which I will max out my whole setup and shoot for 800-900rwhp... what is so weird and unattainable about that?
You don't need 4.5-5.0L to use the S372 or a V8, contrary to popular belief. Although, an S372 on a VH45DE powered 240sx would be awesome if you could get it to fit in the engine bay...i'm sure is possible with enough fabricating, time and money.
And once again, yes my CP piston'd, Carillo Rod'd, built to the hilt KA24DE-T S372R will be daily driven with a/c and make 500-600rwhp on low boost pump gas setting, and 800-900rwhp on race gas. Then my VH45DE track car with its adequate 300-350rwhp will be track oriented but also street driven. If both cars fail me I have a 2008 Titan crew cab that I can safely tow both cars back home in the event of a problem lol... what is the big deal? Why can't you just say thats awesome or best of luck? lol, b/c every build has to have a hater or something wrong with the setup... We all have different intentions with our builds, which mine are def feasible.
Lets face the facts though, I wouldn't be going thru all this effort let alone money if it wasn't going to work. Its also amazing what Haltech can do for a setup like mine. I've spoke to KA24DE engine builders, and borg warner dealers even the 240sx community, it will work and there is always going to be someone who disagrees such as yourself b/c it doesn't make sense...lol. Don't you worry though David everything will work out.
