That's correct. Nissan alphas run 75%~125%, once adjustment hits the rail for a period of time they throw a P0171/174 for lean and a P0172/175 for rich.marekku wrote: ↑Fri Feb 10, 2023 2:17 pmI did some data logging over Consult and found that both A/F Alpha B1 and B2 jump between 78-84% at idle and at around 2k rpm constantly 75%.
Am I correct that it is trimming down the fuel to 75% because it is too rich and the P0175 happens when it can't compensate for the over fueling anymore?
Those plugs are "just rich" and not "I'm gonna foul" rich. The swing rates on the front O2's look okay but maybe not the voltages. If I read your scale correctly they're going near the limit rich (1V) and below normal lean. Healthy swing is generally between 300~600mV, with codes getting thrown around 100mV. So your fronts may have a problem.marekku wrote: ↑Fri Feb 10, 2023 2:17 pmO2 sensors seem to be working as they switch lean/rich as expected. MAF at idle measures 1.34V and 2.1V at 2500 rpm, that seems to be correct according to the FSM.
Attached photo of the data log and also the actual log file that can be opened in nissan data scan. Attached a photo of the spark plug as well, all look the same.
You're misunderstanding something here. The ECM determines fuel trim, it doesn't react to it. It calculates the injector "open" time according to the amount of air coming in, and modifies it in realtime according to whether the front O2's show complete combustion or not. That's what's meant by "closed loop" feedback. So the only way the wrong amount of fuel ever goes in is 1) one of the sensors is fooling it and causing it to miscalculate, or 2) some external factor it can't control directly (like fuel pressure) is overriding the largest adjustment it can make.marekku wrote: ↑Fri Feb 10, 2023 2:17 pmSuspecting that the ecu is injecting too much fuel and the fuel trim can't compensate for that amount, would that be because of high fuel pressure?
I have used the fuel pump control module with the dropping resistor but the fuel pump is the original V35 unit, but the FSM specifies 51psi fuel pressure for both V35 and F50 at idle.
Good plan. This (high fuel pressure) needs to be ruled out as the cause, although one might argue that high fuel pressure would affect both banks (barring a pressure regulation/obstruction issue).
Looking at the logs both banks are rich but only one came up with the P0175.3Q Jay wrote: ↑Sun Feb 12, 2023 8:18 amGood plan. This (high fuel pressure) needs to be ruled out as the cause, although one might argue that high fuel pressure would affect both banks (barring a pressure regulation/obstruction issue).
Check pressure both at idle, and with RPM, preferably under some load if possible.
You said all 4 plugs from bank 2 showed *some* soot fouling (not just the one you attached photo of)?
Thanks for the welcome!
