VK45DE 240SX
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
TOPNIS
Car: 2000 nissan maxima, 2004 nissan maxima, 95 nissan 240sx.
Yellow4g63 wrote:Didn't know you were shooting for 1000+whp, Thought it was just going to be a bolt on swap lol.
lol Yeah but then i got called out by a friend with a built ls1 turbo soooooo you know.ImageImage
budgetbeast
Car: 1995 240SX
Damn dude, this is inspiring, makes me wish I went VK... could you enlighten me on your engine management setup, including the trigger pick ups? I'm running MS3 with the ms3x expansion, just working on a crank trigger setup on my VH41. The flywheel was too close to the block to fit the OE trigger ring. I am running OE vh41 starter on a notched KA trans and OE vq30 flywheel... Thanks
TOPNIS
budgetbeast wrote:Damn dude, this is inspiring, makes me wish I went VK... could you enlighten me on your engine management setup, including the trigger pick ups? I'm running MS3 with the ms3x expansion, just working on a crank trigger setup on my VH41. The flywheel was too close to the block to fit the OE trigger ring. I am running OE vh41 starter on a notched KA trans and OE vq30 flywheel... Thanks
I will be running a mx3 pro ecu with a 36-1 missing tooth trigger wheel connected to the crankshaft pulley or harmonic balancer. Did you say your using a o e vq30de? Is that from a manual maxima transmission?
JoshTex
Car: 2006 Infiniti M35
Hey man, any update on this build?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Bump this up because I too would like to know.
HollywoodJackson
Car: 2004 Infiniti G35
1990 Nissan 240SX Hatchback
1990 Nissan 240SX Coupe
Bump again!
Return to “VH45DE / VK45DE / VK56DE Forum”
