Hey guys this is a swap that i have in the engine and someone told me to post it in here so here it is so far. This is a 2003 infiniti vk45de (v8 engine) thats usually in the fx45, q45 and m45 making 340 hp and 333lb ft of torque in stock mode. wikepedia for those who dont know of it
Quick run through; change the intake for an 06 intake style that the throttle body comes through the front
customize it so i can make a 89-96 q45 throttle body fit on it
modify the oil pan to make engine sit lower in the engine bay
Got the adapter plate from my friend at swap-1uz.com.
For those who are interested ive found that the vh45de from the 89 to 96 q45 transmission bolt pattern is the same as the vk45de from the 2002 to 2005 model. After that nissan (infiniti) switch the starter to the other side in the 2006 and up , which changed the bolt pattern. somthing like what they did to the vh41de in the 97 to 2001 q45. Bolted up the z32 transmission
made some custom mounts for the engine
custom fuel rail tube and 14mm injector bit just arrived this week waiting for fuel lines fittings to arrived to start.
Will follow up when the chance is there.
