I have worn crank in my fx45, 2004 with the standard VK45DE engine. I also have low milege VK45DD which is also with starter on the left side. Do you know if i can bolt the fx heads, inlet etc, on the DD block? I know that both have same 93x82.7mm, but the DD has higher compresion.
Ideas?
Thanks!
