Vis terminator Carbon Fiber hood pins or hood latch?
trayharrell951
Car: 2008 Altima 3.5SL. 2005 350Z, 2010 370z SP
I have recieved my hood and they recommand that I use hood pins. I dont want to use pins because It kinda looks gay. But It still can work with the oem hood system that the car came with. I was also thinking about using hood latch, nice clean look. Thenn I wanted to use hood damper like the one from stillen but I havent seen anyone with an aftermarket hood do that. Any suggestions?
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
it depends on how much faith you have in the latch. i believe the reason most people get hood pins is to prevent the latch from ripping off the hood and having your hood fly open while you're driving. look around, dangeris and another used aerocatch hood pins, they look much nicer than traditional hood pins
ESP
Car: 2008 SexyBlack A/C
Hood pins...use 'em. If you think they look gay (which, really...they usually do on a daily driver...), then consider the AeroCatch flush mount ones like Blackmobile suggested. Dangeris has them, and I've got them. They're considerably more expensive than the competition, but look so much better! I'd also suggest dropping an extra $20 and getting the locking version like I have. On top of that, you should probably also consider the extra $60 or so for the PasswordJDM mounting plates...my hood is secure now. At speeds over 100km/h you can clearly see the hood wobbling...now I have no fear that it's going to come flying up at my windshield!
crayzitalian3
Car: 2007 Nissan Altima 2.5S
hey ESP, i love the carbon fiber hood on your car. I was thinking about getting it for mine, but since my car is precision grey, i think it would look out of place, in my opinion, but i never seen a precision grey with the hood.
about the aerocatch pins. how much did it cost you in total because if i get the hood, thats what i want to secure it down
ESP
Thanks man!
IIRC, the hood latches themselves were about $110-120. The Password:JDM mounting plates were an additional $60 or so... Just google it and you'll find it easily enough. I'd strongly recommend getting the mounting plates...otherwise your hood is being held in place by the heads of six tiny screws! When you're dealing with your safety, it's best to pay for quality rather than cheap out and have to replace your hood/windshield/entire car should the damn thing flip up on the highway.
BTW, I guarantee you'll sh*t bricks when you're installing the AeroCatch latches. With traditional hood pins, you're pretty much just drilling a small hole (enough for the pin to fit through). With the AeroCatch system, you've got to cut out an entire section to fit and flush mount the mechanism. It's not hard to do...just terrifying to cut into your brand new CF hood!
trayharrell951
Thanks
I am getting the Aerocatch flush mount today. Everything should be done for the meet in December . ESP Hope to see you there in San Deigo
trayharrell951
ESP -
Do you have hood dampers?
ESP
trayharrell951 wrote:Thanks
Yup, I'll be there!
...and no, I don't have hood dampers. Not too sure if they'll work with my hood...don't see why they wouldn't though.
trayharrell951
ohh ok so what holds up your hood then?
ESP
trayharrell951 wrote:ohh ok so what holds up your hood then?
Nubile virgins...
trayharrell951
ESP
LOL! I'm just using the stock hood prop for now. I might pick up a set of dampers while I'm down there though... I don't like the way the hood bends when I've got it propped up using that thing.
RaiderKID
Car: 2.5 Percision Grey Altima Coupe
crazyitalian you should go ahead and get the hood post pics so i can get an idea on how it looks on precision grey
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
trayharrell951 wrote:ESP -
ESP wrote:....I don't have hood dampers. Not too sure if they'll work with my hood...don't see why they wouldn't though.
I have the dampers and they work just fine.
