Newcastle82 »
https://forums.nicoclub.com/newcastle82-u13870.html
Mon Apr 18, 2005 7:52 am
Hey man,
The KA, modded properly, has more than enough power to supply the demand of a stock 2900 lb s13. If you've already spent 1200 and you're looking to spend another 3800 or so on mods, and specifically want a new engine, I would do this:
Go to a local machine shop; find someone you can trust. Ask them how much it'll cost to rebuild your SOHC KA engine with 10:1 pistons, bigger valve springs, a performance cam and flat valves. While they're doing the rebuild ask for JE Gapless seal rings, they're about 20 bucks a cylinder, but way worth it. Get a 280zx hi-flow oil pump, an upgraded fuel system with new pump, regulator and injectors, and throw that whole setup together with a set of headers. You'll easily be putting over 200 to the wheels, and you'll smoke stock SR's - I've got this setup in my car, and although I haven't dyno'd it yet (next month, woo!), a buddy with an SR-powered s13 loses every time.
Not to talk trash about japanese turbo engines, like the SR20DE-T or the RB25DE-TT, but why spend thousands of dollars on an engine swap in California that will NEVER pass even the visual inspection of emissions when you can get a fresh, re-built KA with high comp. pistons, valves and cams for about 2500? It's legal, it looks stock, it sounds stock (with the right muffler), it passes smog and it's got gobs of power.
Just my opinion =)
