viper killer
guerilla drifter
Car: 96 nissan 240sx
hey is anyone out there making really big power. 400, 450 or more. i got into a heated argument with a couple of guys about 4 cylinders vs a 302, and a and a v-10. i told them that ill smack them one day but the 5.0 almost runs 10s, and the vipers not far off. i dont really care because i dont do straight lines. i just want to shut them up, what would it take? they both told me they thought drifting was not something you do on purpose. "its just power slidin". that when i left.
stay sideways
guerilla drifter
gue·ril·la /g&-'ri-l&, ge-, g(y)i-/Function: noun: a person who engages in irregular warfare especially as a member of an independent unit carrying out harassment and sabotage
drift·erPronunciation: 'drif-t&rFunction: noun: one that drifts; especially : one that travels or moves about aimlessly. 2 : see also yours truly
BadMojo
Car: 2007 Mazdaspeed 3
Ivan put down about 400 hp to ground on stock internals. There's a thread about it somewhere around here, but I couldn't find it. Dyno sheets and videos below. His car ran high 12's, I believe.
http://www.phatka-t.com/projectcars.htm
TheOne
Car: 93 240sx FB
you can with weight reduction and probably 500hp on internals.(or less hp)
anumeric
Car: 1989 RS13, 1986 AE86 GT-S, 1948 2-Wheel Rickshaw.
Slicks/good drag radials will help aswell.
cosmo
guerilla drifter wrote: i told them that ill smack them one day
Don't be that guy. You know, the one who is always saying "oh wait till I get this" That guy gets annoying after awhile
GEO
Car: 95 240sx KA-T
Man oh man.. 12.7 with 405RWHP? Thats alittle slow, don't y think
BadMojo
GEO wrote:Man oh man.. 12.7 with 405RWHP? Thats alittle slow, don't y think
Actually, I read a bit further. The 405hp #'s were @ 16psi while the 12.7 was run at 14psi. At any rate, the trap speed was a whopping 117mph!
So, maybe traction problems or errr...driver error?
98s14inaz
Car: 2010 Nissan Titan Quad Cab
BadMojo wrote:Ivan put down about 400 hp to ground on stock internals. There's a thread about it somewhere around here, but I couldn't find it. Dyno sheets and videos below. His car ran high 12's, I believe.
Mike Lee put down 535whp on a built KA. He can hold his own against the supra elite here in AZ.
Structure240sx
the talk about ivans car is dumb. guys with 700hp supras can run 12's. its abotu traction, which was mentioned.
like said above dont be the guy "oh well when i get this, or oh cuz you have that" excuse are stupid. currently there are quite a few high hp 240's that CAN run 10's.
BadMojo
Does Aries' car still count?
chandler
Car: 91 civic hb & 96 S14
535? man thats sick, whats his setup if any one knows?
Structure240sx
i believe he's talking about t66240 on freshalloy. t66 turbo at about 29psi, jwt 96# program. i actually think he did 545rwhp with mid 400 ft/lbs
WDRacing
BadMojo wrote:Does Aries' car still count?
Show me where Aries car has ever run a 10...
Your not going to make the 240 a drag machine without working on the suspension. She'll get up and go, but your so far behind off the line because your so seriously traction limited at any decent amount of power. A good LSD, soft drag suspenion in the back, large soft drag radials as well as quite a few other drag race type mods will help lower the usual 2+ 60 ft time. Balance your engine and redo the head so you can extend the rpm to 7500. And lose some weight, rip out the sound proofing...etc.
Basically your car will never run down a fast Rustang or Viper. The 5.0 Mustang is made to go straight...they suck in the twisties. A set of big drag radials and some boost and your going to be have a quick 5.0. Especially the late 80's LX Trunk. The Viper has enough low end grunt to where he can rip your house off the foundation. If he gets traction, your screwed simply because the "Q" range is huge and all of it is useable.
So with the Drift suspension...your not going to net anything under a 12 most likely.
OR my definition
gue·ril·la /g&-'ri-l&, ge-, g(y)i-/Function: noun: A Person who runs through the jungle/desert after cutting down a village full of innocent people. But why run you'll only die tired. Its hard to hide from Helo doing low level over the treetops/sand dunes, just pick up your heat signature and cut you down with a Minigun that has a cyclic rate of 6000 rnds a minute. After which your blood and internal organs leave a huge laid out heat signature almost 4 times the size of the original.
guerilla drifter
yeah im not that guy, that guy is my friend. hes always talkin about gettin this or that. different car different set up every day, and its is annoying. i dont talk i just get it when i get , then i talk. the guy in the viper cant drive at all. he told me 1st is usless to him and he often starts in 2nd just for traction, and the 5.0 guy is terrified of the power. so i figure with good power, some traction, and luck maybe the sun will shine on this doggs *** one day. but untill then ill just stay sideways.
guerilla drifter
as per webster's dicitionary
BadMojo
Coincidentally, I just read that Ivan's car is now in to the 11's. I'm not sure what Aries was running (with a big shot of nitrous) but I'm pretty sure it was in the 11's too.
WDRacing
Aint nothing wrong with Sidewayzzzzzzzz.....
