Viper alarm problem, bad relay?
Gcustoms
Car: 1992 240sx LE
Basically when I arm my alarm I don't get the awesome chirp, when the alarm is armed and going off it makes no noise. But when I'm in the car and I set off the alarm I hear a ticking underneath the dash as if a relay is trying to close. Car starts fine so I'm assuming it's not the battery. Any suggestions?
matt_240sx
Car: 1993 240sx Hatch
I don't know much about alarm systems but if you're not getting any sounds, maybe your siren isn't hooked up right?
Gcustoms
Car: 1992 240sx LE
so how would i test for that?
motoman399
Car: 98' wrecked (RHD coming soon) 240
touch it to a battery. and see if it even works. make sure everything is grounded. i have had problems where it wasnt grounded properly. did you install it yourself?
kietdude
Car: 95 240sx se
Alarm might be in silent mode. Pressing the unlock then lock button multiple times will change the alarm setting.
motoman399
yes and with the door open. ^^
Gcustoms
Car: 1992 240sx LE
motoman399 wrote:touch it to a battery. and see if it even works. make sure everything is grounded. i have had problems where it wasnt grounded properly. did you install it yourself?
no, it was already on it when i bought the car, it worked great up until the batter got sulfated in november, in march i rejuvenated the battery and hooked it up, the alarm was loud and clear, but it just started to quiet down, quieter, quieter and now it just makes a ticking noise from under the dash.
motoman399
ok well it sounds like the siren is going or gone bad. hook it up directly to a battery, that will tell you if its any good. also check for bad grounds.
Gcustoms
Car: 1992 240sx LE
k thx
