Viper 791xv Problems
Post all your Nissan electronics, car audio and stereo questions here!
rhit240sx
Car: '95 240sx
I just "finished" installing the car on my '95 240sx, but the car won't start. I turn the key and the dash lights come on and then nothing, if I try again the lights won't even come on. It also blows the hazard light fuse. The rest of the alarm works fine, the doors lock/unlock and the alarm goes off when I open the hood or door. Anyone have any ideas?
I cut the Black and Yellow wire for the starter, to connect to the green and purple ones from the relay, was I supposed to cut the Black and White one?
Modified by rhit240sx at 3:10 PM 8/28/2006
qsiguy
Car: 1994 Infiniti Q45 Turbo
I replied to your email. The guide on bulldogsecurity says it's the Black/yellow AND the black/white. You also need to make sure you hook the right wire to the lead going out to the starter and the one toward the key. Is the car a manual trans. or auto? If it's a manual then you'll have to wire the remote starts crank output the output of the clutch switch, otherwise it won't crank unless you push the clutch in.
Read my email about the hazard fuse blowing. You might have got your 12VDC+ source from a bad spot or one of many other things. Read the email and post more details.
Here's the link to the bulldogsecurity page.http://bulldogsecurity.com/New...5.htm
