do you mean waste spark? batch fire refers to injectors. just out of curiousity how are you running 5 channels on either the ignition or the injection? most you would need for batch fire / waste spark would be 3 on a 6 cylinder motoreh? wrote:Nothing wrong with 4 ignition outputs, I have 5 with the s1 aem and it runs fine in batch fire mode.
Batch fire/wasted spark, same thing. I have 5 ignition drivers but 3 are used. I also have 10 injector drivers but 6 are used. It's totally configurable.robbie2883 wrote:
to the OP...both aem and haltech are great FULL STAND ALONE options. they will need ALOT more tuning to be running correctly and will most likely need a retune after the first 6-12 months. (mostly for cruise conditions and weather changes) the PFC or any other pnp option will be premapped and MUCH easier to tune and much cheaper. but won't have all the options of a full stand alone. it's really up to what you're comfortable dealing with and how much you want to spend.
is that the platnium? i used to tune with haltech and played with the platnium software while it was in developement. nice stuff, i just am not tuning anymore so have been out of the loop for the past 2 years.toadx8u wrote:yeah you missed the group buy me and los had...i bought 2 haltechs..the best thing about them is they incorporate VE tune...and will auto tune your ecu for the best configuration... then you can fine tune as you see fit...
i gotcha...i did not realize the ame had basemaps for the rb's. having basemaps makes ALL the difference in the worldeh? wrote:
Have to tune more for an aem is totally untrue. I've had the power fc and sold it for the aem. No regrets.Firstly, it already has a base map for RB20,25 and 26. It's drive-able with the base map. It will take a few more minutes to set up the aem with maf vs a pfc because you need to upload the RB25 baseline map to it.
It's is FAR quicker and easier to tune with MAP and boost comp. The Wideband o2 feed back implementation negates the need tune every cell exactly for cruise. I glad I don't have to deal with map trace anymore. There's a s*** ton of things the aem /vipec /haltec can do that a pfc or low cost option (ie: nistune) can't do.
You only need to use the aem cas disk ONLY if you have trouble with timing sync. Seems like only cars with swapped RB's had the problem but most Skylines didn't. FWIW Autech also has a CAS disk for the RB.ItzGenX wrote:The only problem I hear about the AEM units is that you must use their CAS disc (supplied with the ecu). The Haltech units (even the older ones) can function with the stock CAS.
I think I have written about it a few times in terms of knock control (or rather lack thereof) in aftermarket EMS systems, so feel free to do a search for knock and my SN.spolitte wrote:I haven't heard much good news about aem/nistune/ or haltechs knock control features myself; however, from what I understand is that the problem with aftermarket ecu knock detection on a unit like the AEM is the sensor itself, and not the softwares ability to convert a knock signal into a useful piece of data that advances or retards ignition accordingly (mind you this is heresay, information I have picked up from a couple of local tuners as well as a few forums so take it with a grain of salt).
As for the Haltech being able to support peak and hold injectors (low impedance) I believe this is just an added option as it normally is setup for saturated injectors (high impedance), but has the option to run in peak and hold format incase you ever decide to switch to low imp injectors so you won't have to wire up a resistor.
Are you talking about the lack of bandpass filters in the standalones? The S2 aem now has selectable center frequency for knock sensing. Knock Monitoring during combustion cycle is configured with "knock tooth". What if the nissan KS are narrowband, would a bandpass filter be needed?WhatsADSM wrote:
The issue is the NOT lack of features and typically NOT a problem with the knock sensor. The real problem with knock control in the aftermarket EMSes is that the the firmware/hardware is not configured to properly read the stock sensors. Knock sensors are acoustical sensors which should be analyzed in the frequency domain for a specific knock frequency windowed around the most likely time for knock (i.e. just after ignition, while combusting). However most EMSes simply look at the knock sensor voltage in the time domain which is essentially useless. Moral of the story don't rely on the knock detection of almost any EMS out there because it won't be accurate. The best detection would likely be found in the Nistune, since it is utilizing the stock hardware and most of the stock firmware which is tuned correctly to use the stock sensors.
Also in general my vote is for Nistune. It is the best overall for a street/strip car, not to mention the price advantage. If you are going for a more balls-to-the-walls race setup then go with an EMS and I'd probably give the nod to the new haltech p2000 (mind you I have an AEM )
If all the haltech is doing is monitoring raw voltage then no, it doesn't work well and in most cases the stock ECU WILL do a better job since it doesn't just monitor raw knock voltage in the time domain.ItzGenX wrote:The normal universal Haltech units don't even support knock such as the Platinum Sports. The direct plug in Platinum Pro series does support knock control (specifically for it's application), which is available for RB engines. It's not the universal type knock control that monitors raw voltage either from what I was told from a Haltech tech and should work similar to stock.
No matter what type of EMS I tune, I usually use my own home made detonation ears clipped to the block to listen to the engine while tuning. It is basically two high sensitivity computer microphones with wide range of frequency operation epoxied onto all copper battery clips from a pair of jumper cables. I usually clip them both to the block. The wire is the standard stereo microphone wire with 3.5mm jack that goes into the laptop I tune from. I unmute the microphone on the laptop I tune with and use a set of Bose over-the-ear type headphones. These work far better then any knock control I have ever ran into (usually catch pings and such long before the ecu does).
I never knew that was one of the features of the S2. That is awesome that the S2 will correctly bandpass. I wonder how much amplification it can provide... that would be the only missing piece.eh? wrote:
The Platinum Pro direct plug in units should read frequency, not voltage. I said it is NOT the universal voltage reading type.WhatsADSM wrote:
Type of knock sensor would matter a little and if it were a narrowband sensor it would help filter/bandpass some of the frequencies. However you have to realize a few things:eh? wrote:What about the sensor types? I can't find any information about the RB knock sensors. I do know the RB26 and RB20/25 are different. RB26 are black, two pin and RB20/25 are gold, single pin.I *think* RB26 KS are broadband (flat type, non resonate) and the RB20/25 are narrowband ( spike resonant).
If the RB20/25 are narrowband wouldn't that negate the need for a bandpass filter and you can use voltage to determine knock intensity?I've wondered why my KS were so quiet in the aem logs but I think them being narrowband is the reason why.
Sorry for going OT.
Congrats on the purchase. The p2000 is a pretty nice setup and they keep comign out with FW and SW updates to make it better.flatrate wrote:
All this talk about filters amplifiers etc sounds expensive and a waste of time... the old school way still works great
Just my 2 cents
If you plan on using input options such as launch control etc, then don't forget to pick up the optional input harness. Since the Pro version is direct plug and play using the stock harness, it lacks the extra harness wires to hook up the optional in/outs.flatrate wrote:OH, i made a decision and went with the Haltech Platinum Pro plug and play im anxious to pick it apart...
Vipec and AEM are nice systems but i think having fully sequential ignition is a nice fearture to have and should be incorrperated when purchasing a system that cost as much as these do...not to mention its cheaper than both Vipec and AEM
