Violent shimmy/shake on 91 s13 hicas hatch.....above 60mph only
mosr20
Car: sr20 powered s13 and various Zcars ranging 71 to 96
I have a 91 Hicas s13 Fastbackit used to shimmy every now and then.... but now it does it ALL the time above 60mph and shakes rather violently at that!
(Its the front end/steering wheel of the car that shakes)
I'm about to go NUTS as I've troubleshooted it a LOT and now I'm turning to you guys......
I have replaced the following with known good parts from parts cars I have on hand here already........these did NOT solve the problem....
Items I've replaced include:
1) tension rods2) changing the front tires (thought it might be an unbalanced wheel/tire but no3)put in another steering rack.....4) changed strut spring assembly in the front5) put Hicas hubs w/abs assembly on from a hicas parts car i have6)replaced lower control arms (with ball joints)7) I even turned the abs off via pulling the fuse & fusable link to make sure it wasnt causing the issue......8) I checked the holes on the back side of the crossmember that like to wear oval shaped and they looked to be ok...... not much wear so that shouldnt be it (where the lower control arms bolt in)
I need some more ideas!!!
Please help!
Next I plan to replace the steering collumn but Id rather it not come to that......
I posted in the tech forum b4 I remembered that I might get a better response here.... if that thread needs deleted please do so........
if anyone has some advice -- please share~
thanks!
Damon
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
That sounds like unbalanced tires, but it could be something bend?
Instead of sticking all this money into it, have your tires balanced by Geralds for free, if that doesnt work, take it to nissan and pay 80 for a full diagnostic..
onosqv
Car: '92 240sx Vert
Have you had your car aligned?
