violent shake when car is running
michaelgrigoras
Car: 1991 nissan 240sx
it just started yesterday night i drove to my gfs house parked it later that night started it and it started shaking violently no idea why replaced bad fuel injector before this problem has occured also replaced head gasket no fluids leaking could it be a mass air flow sensor or more bad fuel injectors? any comments will help please and thank you :gotme
krash
MAF would put it in "limp" mode, meaning it won't go above 3k rpm or so. Guessing its another bad injector. I had to change 3 on mine, one after another, before the problem went away.
michaelgrigoras
is there an easy way i would be able to check if it was a faulty fuel injector?? ive heard taking one injector out will let you know if its bad while the car is running
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Unplugging each injector one at a time. Unplug one if it stumbles, plug it back in and try the next. Same can be done for spark.
Dattebayo
Violent shaking means something (spark plug or injector) isn't firing on either cylinder #1 or #4.
AZ89two4Tsx
Are you sure your motor mounts aren't broken? lol
alms24sebring
'04 Nissan Sentra SER SpecV
sounds like a missfire. Better hope you did that head gasket right
sandcrabsailor
Car: 1993 240sx SE HB
Are you sure the violent shaking of your car didn't have something to do with you and your girlfriend? :D
94_240sx
Car: 94_240SX
Injector... That's the first thing to check.
michaelgrigoras
checked out the fuel injectors turns out 2 are bad thanks for all the help its greatly appreciated! :biggrin:
