Dabizzo1 »
https://forums.nicoclub.com/dabizzo1-u52713.html
Tue Feb 13, 2007 11:26 pm
I recently brought a 94 Q45 I purchased from Dallas from Dallas back to mechanical happiness under the hood and after replacing injectors, replacing knock sensors, plugs, MAF, pcv, vacuum lines, all fluid flushes, and thoroughly cleaning the plenum and the entire air intake system, I found 2 main culprits that would affect the car at speed, especially under an inclined load. First, if the IAC is dirty and if the seal is not perfect, the car will have fluctuations at idle...a vacuum leak basically. But at speed, only assuming the rest of the vacuum and fuel systems are in order, a completely blocked EGR pathway will cause a wonky vibration under load. Mine was literally blocked shut with carbon at tghe 90 degree neck inlet in the plenum itself. With a flathead screwdriver, long allen wrenches for the sharp bend, and long bristle brushes from a gun cleaning kit, I literally strongarmed the carbon out until the passageway was clear. To my understanding, the purpose of the EGR system is to introduce cooler exhaust air into the airbox in order to prevent detonation within the cylinder at speed, which could be manifested by a violent shake while in motion. Now also, even though the injectors ohmed within range on your car, something I discovered when I removed mine for replacement was rust on the diffuser tips, which not only restricts a good spray pattern, but is also a strong indicator of water in the fuel. Such a physical failure of a crucial part will manifest itself at all speeds. My car is a testament to the damaging effects of ethanolized fuel on a fuel system. The first things I had to change were the fuel pump (very rusted in some areas) and the fuel injectors. With the guidance of this site, my car now runs as close to perfect oem as a 13 year old car can get.
I'd recommend you do a full plenum cleaning (especially the EGR pathways) and if no change, continue your diagnosis from there. As the veterans of this site have preached through experience, perfect engine operation begins with clean internals in the air/fuel mix systems. Without that first, any diagnosis will have much difficulty in pinpointing the culprit. Good luck. Boris P.
