Vin # locations
spoolinnnt
Car: 95 Nissan 240sx
How many places is the vin # stamped onto the frame? I know it is on the plate on the fire wall and then eched into the wall its self but i dont see a plate on the dash. And i just wanted to check if there is anywhere else. I bought this car and the # is shaved off the wall and I need to check to see if there is anouther one on the frame to see if its the same. thanks
AkademikONE
There's a VIN stamp on the dashboard, right on the top left corner, you can see it through the windshield. Also, on both door jambs, there should be a stamp or a sticker there.
spoolinnnt
is it like that for the s14 because i dont see the one on the dash ill look on the door jams. thanks
Aries
Car: LT1 240SS
it is also stickered to the body above the gas tank
