Video of my CA
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Here's a video like I promised in the other thread. Not too exciting. The nismo mounts cause my intake to rattle though... its not the motor making noise Motor is smooth as a baby's bottom.
Right-Click Save-As http://www.escic.com/CAinstall/CA18DET.avi
MegasquirtCA
Car: 240sx
Woot Woot its about time. Glad to see you finally done my boy.
OmarM
Car: 1989 Nissan 240sx HB
Three things, what exhaust setup do you have? You are running way way too rich at idle, and probably is the reason i ask about the exhaust. Oh yeah and fix that intake pipe, can enjoy the sound of a smooth running engine with that racket. But other than those things.
Shes Beautiful
s14db
Car: 1998 240sx
Sw33t camera work...
c-rad
s14db wrote:Sw33t camera work...
I didn't even know you were on here...
So yeah, he worked the camera.
dvd
idling pretty high there
c-rad
dvd wrote:idling pretty high there
Yeah it was. I drove it last night though and it was idling right at 750-800. I might switch out my idle speed controller and see what happens. That of course is after I check for boost/vacuum leaks.
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
"Pretty rich you think"
:lol: funny accent !!
But yeah, at idle mine sits arfound 14.7 a/f.. Sounds nice, i like the s/s manifold.. nice one dude !
c-rad
rexhunta wrote:"Pretty rich you think"
That wasn't me... thats s14db above saying that.
s14db
Car: 1998 240sx
This from a Banana bender
I still can't believe you took it for it's first drive at night.
rico05
Car: 1992 RMS13 w/ CA18DET
We need some WOT footage.
c-rad
rico05 wrote:We need some WOT footage.
WOT = not possible the way it is now. As soon as I figure out wtf is making it run like **** under accel, I'll try and get more video.
rico05
Ooohh, that sucks Chris. GL getting it fixed. THEN, we demand WOT video!!!
BTW, refresh my memory: what turbo you running? Even with little spooling going on, you can sure hear it nicely!
OmarM
Its probably running way too rich and thats why it runs like **** under load. Imagine if you are running 10.6 A/F at idle it will probably only get richer as you give it more load. Also if there is a loose intercooler pipe or your maf is fubar then it will not run under load.
s14db
Car: 1998 240sx
He's Running a T-25.
There is a boost leak somewhere around the manifold. Needs to come over and hook up to my air compressor to find it.
c-rad
s14db wrote:He's Running a T-25.
It's an SR20 T25.
c-rad
OmarM wrote:Its probably running way too rich and thats why it runs like **** under load. Imagine if you are running 10.6 A/F at idle it will probably only get richer as you give it more load. Also if there is a loose intercooler pipe or your maf is fubar then it will not run under load.
Now its 15.9 at idle... I didnt touch anything.
rexhunta
MY10 Forester X LE
s14db wrote:This from a Banana bender
Banana Benders are from Queensland WA people are Sandgropers which are a fish
kungfuhamsta
Car: '91 240sx KA24DE
nice job man. i was wondering where you got your parts from...i'm in central fl. too but having a hard time finding anyplace with ca18's or anyplace willing to do the swap...
s14db
Car: 1998 240sx
kungfuhamsta wrote:nice job man. i was wondering where you got your parts from...i'm in central fl. too but having a hard time finding anyplace with ca18's or anyplace willing to do the swap...
Well, you can't do it at my house...
c-rad
s14db wrote:Well, you can't do it at my house...
Speaking of your house... can I come by today to do the boost leak test?
And as far as parts... I got everything from either Nissan, Advance Auto Parts, or Ebay. The motor itself I got from a friend. The install I did with a little help from a couple of my friends.
s14db
Car: 1998 240sx
c-rad wrote:Speaking of your house... can I come by today to do the boost leak test?
Good luck, The ***** next door just got home.
dvd
i wish i had some helpful ca people locally like you guys *tears
I can't wait for WOT video =] Your exhaust sounds kinda gross though =\ sorry.
c-rad
It's an SSauto... what do you expect? Sounds a****load better than it did though with the KA.
s14db
Car: 1998 240sx
c-rad wrote:It's an SSauto... what do you expect? Sounds a****load better than it did though with the KA.
Sounds a lot better than the KA did. Still sounded kinda ricey as you peeled out of my neighborhood. No competition for me
When you going to install that BOV? Compressor surge sounds horrible.
c-rad
s14db wrote:Sounds a lot better than the KA did. Still sounded kinda ricey as you peeled out of my neighborhood. No competition for me
BOV is going on this weekend or early next week. I am just too lazy to take the IC pipe off and get the flange welded on
Oh, and I found out I have a few nasty boost leaks. One at the intercooler inlet, a MASSIVE one at the idle control unit, and the stupid #1 injector seal (where it sits in the manifold). I only fixed the intercooler pipe leak so far and it already made a decent bit of difference. The idle air leak should get the car running pretty damn good. We'll see though!
float_6969
Sometimes MAFS systems suck. Can't be helped in stock form though.
Bwana
Car: Denali
float_6969 wrote:Sometimes MAFS systems suck. Can't be helped in stock form though.
MAP ftw!
Seriously, I had a bad clamp on my IC piping that I kept blowing apart , but I'd just drive on untill I had a good place to stop and fix it, no stumbling, but no boost!
That engine looks GREAT in there! You've done an awesome job with it and good luck with getting the glitches straightened out and everything tuned!
hsoj_v
Car: Nissan 200sx XE (Silvia S12)
What kind of BOV are you using in that vid?
Nice engine btw.
c-rad
hsoj_v wrote:What kind of BOV are you using in that vid?
Nice engine btw.
read the thread
Thanks
