VIDEO: Despite 11-12AFR, blew the motor
accel junky
ftp://240user:[email protected]/2 ... 20SRT4.MOV
Copy and paste the link to get the vid!
In video: I don't get 1 bar until 4900rpms and when I shift to the next gear, I have to almost completely respool (SUPER LAG!!!). Watch the boost gauge.
Well, having tuned the beast to 11-12 afr across the board (PLX Wideband/SAFCII) I somehow managed to screw up my motor.
After some test runs and a race...
I did a compression test and got 115,60,115,115,90,45 .....ouch.
I'm betting on blown rings, but maybe a headgasket? I ****-ton of smoke blew out in a race vs. a modded SRT-4 running 19psi. I was running 1 BAR.
Car won't idle on its own now. Also, I BLEW THE PCV VALVE OUT OF THE VALVE COVER AND OIL WENT EVERYWHERE....WTF???
Any ideas? My options so far are:
A. Rebuild the motor with forgies (CP pistons/Pauter rods) $3500B. Sell rb25, turbo, motor, crossmember, and all RB25 specific parts and acquire RB26 to run 400whp on stock injectors and rebuilt stock turbos. $8000-$RB25StuffSoldC. Hang myself.
Modified by accel junky at 8:50 PM 3/14/2005
Modified by accel junky at 8:52 PM 3/14/2005
Modified by accel junky at 8:53 PM 3/14/2005
Modified by accel junky at 8:54 PM 3/14/2005
yellow_jacket
Car: 95 240sx
Your luck is incredible! I was looking forward to seeing your car at one of the upcoming meets.
From the sounds of it, you might have blown the rings. When the rings go it pressurizes the crankcase and oil will blow all into everything. You can pressurize the cylinders and see if the air is leaking out of the motor or the intake or exhaust.
How much timing were you running? Do you have a egt gauge? How much power were you making?
If you decide to part the motor let me know. I could use quite a bit of the parts that you have.
I would love to know what you decide to do with the car and if you decide to go rb26.
Joe
if your PCV blew out its definatley rings.
how you blew them apart with a 12ish AFR is beyond me. thats pretty hard to do running that rich. id do a leakdown test asap to verify tho.
sorry for the luck. time for a 26
what was your fuel setup? what about engine managment?
kouki-gymkhana
Car: 1993 Nissan 240SX (only 90,000 mi!)
Goddamn it, accel junky! WTF! I was so psyched that you finally got that thing on the road and then you grenade it like that. Shheessh! No but seriously, that sucks big hairy balls that you're back to the drawing board with that project. Let us know if you are going to part it out though. I personally would rebuild it with forgies and get that thing running again.
BTW: Linkie no workie for the vid
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
accel junky wrote:C. Hang myself.
Go for C.
j/k It was prob ignition timming that did you in. Were you data logging when it happened?
T_love
Damn man, that really sucks. I thought your problems were finally coming to an end.
I say rebuild, coz now you are a little more experienced with the RB25 and it should be easier to get the next one going
accel junky
Yea... the timing thing did cross my mind. I had the CAS set the way it was when the motor was delivered. I probably got a dang piece o' crap motor to begin with, because it came from Osaka ultimately (long story).
I'm thinking what Kamin said is probably the case.
accel junky
Kamin wrote:if your PCV blew out its definatley rings.
Fuel setup: PE 550cc's, SAFCII. I had a PFC but it was shorted so its currently getting repaired at Apexi of Japan.
Joe
SAFC?ding ding ding ding
that thing wreaks HAVOK on ignition maps when you use it to tune a heavily modified engine (wich yours was)
goofynick6
Car: 1995 S14.5 RB20DET
I'm thinking the safc hurt you, plus the turbo sounds like it was dealing with an enormous leak to spool that slowly, meaning it was spinning way too fast and out of its efficiency range = super hot air and that's just plain bad.
Sorry to hear man, that really sucks.
NIck
y3llows14
Sorry to hear bro. I know how it sucks to have one thing messed up after another. But yeah, part it out so I can get your intake manifold Would have love to race you too since we have similar setups.
b16_madman
Car: 88 honda civic dx, jdm out the wazoo
Good luck on the rebuild. The devil himself isn't even on your side on this one.
Oh well, when it's all said and done, weeee..
someone said to add option d...
d.ka-t baby!
gaw man, if i can help, i will
I honestly thought you were joking in the email you sent me. And dude, the cluster still doesn't work? I think you should part it out, and mod the m3
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
Rebuild the motor but you might get a EGT gauge
accel junky
sean8564 wrote:Rebuild the motor but you might get a EGT gauge
I thought about getting 1 just for the 6th cyl....
But I wonder how much for monitoring all 6 cyl individually?
sean8564
1993 Nissan Silvia
is you intake plenum made by trust or tophatperformance
accel junky
sean8564 wrote:is you intake plenum made by trust or tophatperformance
Trust/GReddy
sean8564
1993 Nissan Silvia
ok because the one that tophat makes you last two cylinders will run rich
Carl H
sean8564 wrote:ok because the one that tophat makes you last two cylinders will run rich
no thats wrong, any front facing plenum including the stock gtr makes the last 2 cyl run LEAN.oh and even tho everyone else has said this i will too, safc is poo poo.
sean8564
1993 Nissan Silvia
Sorry about that you are right it runs lean excpet for the trust for some reason dose not make the motor run lean from what i have been told.
