Hey guys, first time Ive ever had this issue, came out of work and my car wont start, just cranks and crank and cranks but no engine start or even attempt to fire. I veryfied I have fuel pressure at the fuel rail as I have an aftermarket gauge installed form when I put this reman engine in 2 years ago. Here is a video of what is happening
https://www.youtube.com/watch?v=B0jKn6W ... e=youtu.be
I tried disconnecting the battery for 20 min, and the car is now sitting on a battery charger. Im hoping to check spark and possibly timing if possible next, can you check spark on a coil pack car like a traditional car with a distributor/spark plug? I wasnt sure so I didnt want to try without verifying.
One thing I think I should mention is the car throws a P0505 idle air control valve error, and has for the last 4 years, it currently has no stored codes though. But Ive read to fix teh IACV you have to repair/replace a computer aswell, but the problem has been there for years, I just have to tap the gas when starting it as it hasnt had a high cold start idle since it threw P0505 so long ago.
I do have a code reader with a live data function, ive actually never used it, but maybe that could shed some useful information? Anything specific I should be watching?
I got the car towed home, and I will disconnect the battery overnight while I go to work, but Im doubtful that is going to help. Im open to all suggestions and will do them promptly. Thanks for the help!
