No, I was on a strict budget so I had to reuse 90% of the old stuff. The engine had about 130k on it. I re-assembled the heads only to find the section on bleeding the hla's after the fact so I had to tear them down again and bleed them properly.David Steele wrote:Are the HLA's new ?
That sounds cool. I'm going to check the coils today but I may still pick them up from you after xmas. That way I only have to send off 2 to get cleaned and checked.tmorgan4 wrote:Damn....you got yours running before I did!? Congrats...now I get to ask you all sorts of wiring questions when I can't get mine to start.
If you need any injectors I have 6 "good" ones that Deatschwerks cleaned/flow-tested still in the little bags. They talked me into all "new" phase 2s since I really didn't want to pull that damn plenum off.
Oh I missed that.T45 wrote:Well I just rebuilt the engine so I'm confident in the compression.
