Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Mon Apr 12, 2004 11:05 am
Code 53 is the Exhaust Gas Sensor (commonly known as an oxygen sensor) on the right bank. The Early Qs don't have an EGR temp. sensor unless they're set up for California Emissions. I'd replace both O2 sensors first and see what happens. This is something you want to address quickly, because you run the risk of melting your pre-cats if the fuel mixture is too rich. It's unusual to have an outright failure of the O2 sensors, but they'll typically get sluggish by 60-100K.
For 21, be sure to check your connections at the transistor packs on each bank, the CAS connections, etc.
Good luck!
Heath
