Well that's a releif..01silvapathy wrote:I never use my auto mode anymore cause I cant with the manual hubs I got. Anyways whenever im wheeling or using 4wd and I turn the truck off or put it in park you do get a kind of jerk or thump sometimes. Thats just the slack going out of the driveline its perfectly normal.
Kidastra wrote:I had the exact same vibration feeling in my floor and seats, I work at a nissan dealership so I had alot of different input of what the problem may be,
in my case it was the front drive shaft, and my front left wheel bearing.
I'm going to have to try this!fleurys wrote:Your problem is the front u-joint. easy to test : (make sure to test this in a straight line...if you do this while turning you could damage the driveline)
1) put on 2wd : floor it from a stop to 30-40mph should be no vibration or very little
2) put to 4hi : same thing ... should be vibrating alot and potentially feeling that if you continue to accelerate, you might break something.
if that's the case, it's your u-joint. take 20 minutes, and remove the 8 bolts retaining your front driveshaft. Once you have it in your hand , you will be able to see that the u-joint is either seized or cupped (it moves in steps, like if the rollers in the u-joint caps were square instead of round)
+101silvapathy wrote:I'm going to have to try this!fleurys wrote:Your problem is the front u-joint. easy to test : (make sure to test this in a straight line...if you do this while turning you could damage the driveline)
sweet... hopefully I can get to this, this week, Man, I just wish I had this info 2 weeks ago when I my pads and rotors done.....Kidastra wrote:When I had my driveshaft out, it had no signs of wear the the joints. Even after I changed the drive shaft there was still a slight vibration, which is where the bearing came in, once that was repacked all vibrations were gone.
Which bearing(transfer case?) and for which drive shaft(front or rear) are you referring? I had a thread about this a couple months ago. Any info would be great.Kidastra wrote:When I had my driveshaft out, it had no signs of wear the the joints. Even after I changed the drive shaft there was still a slight vibration, which is where the bearing came in, once that was repacked all vibrations were gone.
Bearing was actually the wheel bearing, just had to repack the grease, and tighten it up.Pathfound49 wrote:
in my case that "test" did confirm the vibrations, but when the front driveshaft was out, the joints were not seized, or cupped. So it is possible that it is off balance also.fleurys wrote:Your problem is the front u-joint. easy to test : (make sure to test this in a straight line...if you do this while turning you could damage the driveline)
Ok Kid. Thanks for the reply.Kidastra wrote:Bearing was actually the wheel bearing, just had to repack the grease, and tighten it up.Pathfound49 wrote:
and I was referring to the front drive shaft.
