Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Sep 30, 2003 3:15 pm
A hundred thousand miles of fuel abuse can't be FIXED over night or in a week, or a month! Unless you change everything and $3,000 is a bit much for most people.BG44k is a mild cleaner not the end all of cleaners, something that is to be used every 3,000-4,000 miles to clean up the loose easy stuff and keep matters from getting worse.
BG has 4 different [strength] fuel products depending on the severity and risk you are willing to assume. BG44k is the mildest and the only one safe for the owner to use.Can't make a mistake in pouring it in tank assuming there is more than 5 gallons of fuel to dilute it ........11/650=2% extra detergent/solvent additive.
Much of the crud comes from the fuel flex hoses as after year the interiors begin to breakdown. They should be replaced every 100-150k........HP fuel hose is expensive and lots of junk on the market that doesn't meet oem specs.
